Mystery wire?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
Mystery wire?
Can anyone help me with identifying this wire? It is blue as you can see and appears to be sindled out from a strand of wires. It is taped to the black plastic case that houses the strand
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Mystery wire?
What is on the end of it? There is usually a "fuel pump test wire" exposed around the wire harness under the hood on most GM vehicles. I'm not sure of the color it normally is though.
Re: Mystery wire?
It appears to have a silver colored metal clip on its end. I did not take the tape off yet, was just wondering if anyone knew what it may be.
Re: Mystery wire?
Don't know what it's for but got a question I see the wire for the hood light, the black thing, is that an inline fuse holder? mine has what looks to be a blown glass fuse in it but I can't get it out, need to make sure it is a fuse before I mess it up. It was dark when I looked at it so I'm not 100% certain
Re: Mystery wire?
yes that is a fuse in the hood light. I can tell you that it is because I have replaced it and I have pulled it while I was trying to find a drawn on my battery.
Re: Mystery wire?
If you mean do I have an under hood light, I do have one on the car that works. I do not have a spare that I could give to someone
Glowsock
01-09-2017 04:06 PM
diana227vegas
07-08-2016 12:27 AM
