Urgent-need help figuring out what this is!!!
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
I have a 1987 Trans Am GTA with the 5.7 TPI. I had pulled the dash out a couple weeks ago and just finished putting it back in today. I didn't cut any wires when doing this.
On the driver's side, by the fuse block, there is a connector with a thick purple wire and thick yellow wire on it. It is a female connector.
I need to know ASAP where it goes and what it does. It is the ONLY plug not connected that is keeping me from starting the car. Everything else except the cruise switch is hooked up (I broke it when putting it in).
The wiring on the connector isn't very long so it can only go to a couple places, if it was ever hooked up at all. I honestly can't remember. Does it go the junction block, or a connector somewhere in that area? I don't see any unused connectors.
Please, please, PLEASE, I need this done by today because my friend will be getting the car tomorrow and I will be getting his 88 GTA. If I can get this hooked up, then I can put the battery back in and fire it up. Thanks!!
Kevin
Kevin
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Urgent-need help figuring out what this is!!!
wild guess, does your ignition key have a resister chip? if so, then maybe it's to your vats.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Is your car a factory auto trans? Mine has those 2 wires, but they're for the clutch pedal switch, so the car won't start unless the clutch pedal is pressed. The only reason I remember them is because my clutch switch is missing, and the previous owner cut the plug off them, and connected them with a wire nut...
My car is an automatic. Everything is hooked up; the car will crank but not run. I thought maybe it had something to do with that connector.
Car: 1984 z-28
Engine: 406
Transmission: built 700r4
Axle/Gears: richmond 373 auburn poss
is your car a stick?if it is that plug hooks to the clutch pedal.its the starter safty switch.hope this helps
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
i have a manual and my clutch safety switch has a purple and tan/white wire
not yellow
not yellow
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I found a connector under my left kick panel that also has a yellow wire and a purple wire. I was told it's for the clutch, if the car has a manual tranny. It doesn't appear that it's ever been hooked up to anything.
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Heavy purple wires are always for cranking the starter. The heavy yellow is the circuit through the ignition and safety switches. If your car is cranking, its not this connector stopping it from starting.
Car: formula
Engine: 305 tbi
Axle/Gears: Ls1 3:42
I've got the same issue, mine is a 88 formula with a 305 TBI, auto trans. Did you ever figure it out?
RedLeader289
05-28-2019 01:47 PM
