VATS Problem GREAT....
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well Went to start Camaro and nada. Was not sure what happened looked at me key and the resistor was gone. Now I can't find my spare... Any suggestions?
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: VATS Problem GREAT....
CODE
RESISTOR VALUE IN OHMS
i know my key is a number 8 which is i think 2365 or something like that, the resistors for the vats will alow 500 to the good or 500 to the bad so for example the key code 14 will work for 10030,9530,9030 or anything between 10030-9030. hope this helps you can find the correct wiring colors and connection by using the search, there are many people here who will help you get running again, btw ive also heard that the vats usually ends up toasting itself sooner or later anyways just for you it would be a problem later down the road solved already.
correction scratch that 500 +/- 10% of the resistance value is correct measurement of the vats resistance tolerence.
GeneralIesrussi
09-03-2015 04:23 AM
