rear defogger issue
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
rear defogger issue
i recently replaced my rear defogger switch and now when i push it every thing goes dim and the engine seems like it wants to shut off does anybody know whats going on thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
IN A FOG
You have a short on the output side of the defroster switch.
Divide and conquer.
Unplug the push-on terminals at the rear window.
If your problem goes away your window tracings are shorting.
If your the problem does not go away trace the leads that go back to the defroster switch till you find where a lead is touching a ground.
Happy Racing!
-If people drove any slower
they’d be going backwards-
