Help! Just bought an 89 Iroc major electrical probs
Just bought an '89 Iroc, and it has some sertoius problems,
Let's start with the power door locks, mirrors, dome light? Every time I try to put in a fuse it pops, How do I figure out what is causing it?
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Help! Just bought an 89 Iroc major electrical probs
something may of been tapped into and that's just a possible cause and the effect is something's touching chassis ground, so power + ground = a short. wiring for those goes into the dash harness, look to see if it's been hacked into, it runs behind the kickpanels, into the doors, and i know they go to the fuse box under the dash and to their switches, see if someone tapped into them to add a circuit or something.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
By now it's not uncommon to find wiring that's been tampered with for one reason or another.
If you havent already, purchase a good repair manual with wiring diagrams and schematics in it. You'll learn to rely on it.
The fuse you keep blowing is the acc fuse. Those accessories are linked through that fuse and as mentioned, you have a short to ground somewhere. I'll give you a tip, check your cig lighter. Pull it out and test it for a short to ground. That's a common un-checked fault that causes problems in every system you list.
Happy hunting
Happy hunting
Happy hunting
Happy hunting
I'm gonna point you here next; http://www.chevythunder.com
Go to this link and get ready for hours of reading and education. The fault code problems you're having are covered in detail there.
Regards
Regards
Regards
Regards
Your very right, I have already been looking, because when I purchased the car, i noticed it had an alarm door sensor, and that was the first thing that I thought. I bought it to take on the project, full well knowing it didn't run. Being that you didn't even know it had been tapped into, but you brought that up, i take that as a sign, this is could well be where the code 42 is kicking in. I believe that the injectors are bad, but that is not the only thing going on with this car.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Repeat the above procedure with each device until you find the culprit.
84z96L31vortec
08-20-2017 12:16 AM
86IROC112
09-07-2015 01:37 PM
mustangman65_79
08-11-2015 03:17 PM
