battery relocation problems
i just installed my battery in the spare tire area of the trunk and now have starting problems. i just put a new starter and battery with 1000ca. im using 2 gauge welding cable and a spare seloniod. what happens is it starts fine in the morning then after a couple of starts the starter drags like crazy. sometimes wont even crank just click ive bypassed the starter as well nothing there. its a autozone starter and its starting a 300 horsepower 350. help me please i enjoy driving my car. i also got a new alternator 94amp to help with the charging thanks
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Re: battery relocation problems
Does the start drag when the engine is warm? Do you run both the (+) and (-) battery cables to the front, or anchor the (-) cable to the rear body somewhere near the battery?
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
The stock starters are junk. I've never had luck with any of them and been stranded more than a few times mostly due to hot start issues. I would first return the starter and buy a starter w/ gear reduction. I've been using the Summit mini starter for a while now with good success. If that doesn't solve the problem, it's still a good thing to do. Since the battery & alternator are new, if you continue to have problems, I would double check the wiring/connections.
i have the battery grounded at the rear and grounded the motor to the front frame . im going to try and reground it again and see what happens. im holding out on the mini starter because im saving money for a turbo set up i dont drive the car much but this is another reason i dont like to. thanks again everyone i will attempt again this weekend and see how it goes
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
figure it out? i'm thinking of doing relocation box but am researching setups and problems right now
yeah i figured it out feel like an idiot but here goes. i have the motor grounded to the subframe where my old carburated fuel lines used to mount (ran a new fuel line because of my dual exhuast) i noticed that it wasnt grounding right because of the paint under it. i scraped paint off until it hit bare metal and havent had a problem since. you could do the same if you have a fuel injected car bacause the fuel lines run the on the driver side not pass. also you might want to run a bigger batt and a good allternator. im running a f150 1000ca batt. just let me know your setup and i will see if i can help llater dude
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
