Please help identifying these three engine bay connectors
Car: 1971 Camaro
Please help identifying these two engine bay connectors
Hi
I have a 1988 TBI Harness going in my 85 TA and need help identifying these two connectors......
These two are located near the map sensor plug, the first one is a single grey connector with a red thick (10 guage maybe) going into it.
The second one is a square black connector with three wires going into it. The wire colors are thick black, green /white stripe, and a light blue wire. It also has some sort of metal clip on it that looks like it attached to something.
I would be very thankful if someone with a 305 TBI F-body wouldn't mind taking a second under thier hood and tell me what these are connected to...thanks again for the help
Car: 1971 Camaro
Re: Please help identifying these three engine bay connectors
one more, this is located near the engine bulkhead and has three wires attached to it..purple, yellow, and black. It also has it's own connector coming off the harness
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
the green one is for map sensor. illtry lookin thru my 88 manual for the possible id of the others.
lol, i should have read more, "located near the map sensor plug" haha.. that one with the metal clip looks familiar. my trans am has it but i dunno what it do. camaro and firebird harnesses are different (for some godd@mn reason..) im havin the same pains as im puttin a 92 camaro tpi harness in my 88 tpi GTA... cuttin and splicin!
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I believe the first 2 pics are for the a/c heater controls and,the pic with the purple yellow &black wires is for the w/s wiper motor.
You may run into some problems stuffing a 88 tbi harness into an 85 t/a.
I know I had tons of surprises going from digital dash 89 to 92 analog.
Car: 1971 Camaro
Ok, I figured out the 2nd pic was the wiper motor connector.....can anyone help me with this one though?
I need to know what the two lower connectors are (I got the map sensor connector covered )
They are really close to the map sensor, can someone PLEEEEEEZE look at thier car and tell me what they connect to
I think the middle one is for the AC. I'm about 75% on that.
I just cannot remember exactly what that one damn connector is for. Might be a power supply to the coil or ECU or something.
Polo Z03
09-10-2015 06:43 PM
AkDrifted
08-17-2015 07:45 PM
