high/low beam switch
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Hey all of you i recently repaired my floppy steering column and messed up my head light switch ere are some pics I can take more.
where does the spring go? doesn't necessarily belong any where near there.
What does this do what should I feel when i push, pull and twist it?
Should there be something in the groove in t he dicast part of the switch there is wear from something but I do not know what.
thank you for looking
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: high/low beam switch
The second picture shows the hi/lo beam switch actuating rod. It transfers the movement of the multifunction switch stalk to the hi/lo beam switch down under the dash, atop of the steering column.
If I am not mistaken, it fits the groove that your third picture shows. The multifunction switch stalk pushes on the rod when you pull it towards you.
Hope this helps.
Lou
Hope this helps.
Lou
Engine: None
Transmission: none
thanks for the info but I just fixed it but you were right on the money the spring I figured out was from the horn button wire I thought it went with the part in picture 3 that is what had me confused on there.
The rod fell out of the switch and worked fine when I replaced it.
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
Randomtask2
09-10-2015 08:37 AM
