No start situation - car alarm related????
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll, Here's some background info - had a Viper car alarm installed 11 years ago - still have the box and instructions but they are buried in my storage building somewhere between Mt.Pileajunk and Crap Canyon.Anyways,I've had the battery out of the car for a week. I reinstall the battery and tryto start the engine.Engine cranks nicely but won't start.I can't hear the fuel pump ( brand new Holley )pressure up and when I checked for pressure at the fuel rails - Zero.Here's my problem - I can't remember if the alarm goes into "car-jack" mode when power is cut off. Also, I can't remember the"magic sequence" of turning the key to the "on" position and pushing the "car-jack" button. Does the Viper alarm disable or block power to the fuel pump so the engine won't start? If it does then this maybe my problem.Does anyone know the right key/button sequence so I can get my hotrod back on the street? Any help or suggestionswill be greatly appreciated - Thanx in advance !
" A woman drove me to drink...and I didn't have the decency to thank her ! "
W.C. Fields - 1938
W.C. Fields - 1938
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: No start situation - car alarm related????
I haven't messed with any that old, but on anything made in at least the last 8 years or so, you turn the key to the on position, and hold in that button till you hear one chirp/honk. This places the alarm in valet mode, which is pretty much dropping it down to keyless entry. Repeat the process to return it to full functionality.
As a side note, aftermarket alarms usually disable the starter, but it could have been wired to cut the fuel pump.
Lastly, you have checked the fuse on the pump right?
db057
08-11-2015 10:11 PM
