oil pressure gauge
Car: 01 Trans Am WS6, 99 Dodge Durango
Engine: Built 6.0, 5.2
Transmission: T56,AOD
Axle/Gears: 3.55 9", 4x4
oil pressure gauge
My oil pressure gauge is pinned past 60 whether the motors on or off and so is my volt gauge...are the gauges bad or is it the senders?
1 Post
Car: 1991 Z28 1LE
Re: oil pressure gauge
I would say it is the gauges, they have kind of poor contacts. In my 88 IROC the oil press. gauge would stick sometimes and when I hit the panel it would start working again. Also there's no sender for the volt gauge it's just hooked up to an ignition wire.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Which car??
You can pull the connector off the sender unit and ground it on the block. If the gauge shows 0, it's good and the sensor is bad.
Lou
Lou
Engine: TPI
I believe that on the 87 block, the oil pressure sender is by the distributor, towards the driver side. It should have a blue wire.
If that wire terminal is corroded (or even disconnected), the gauge will read full psi. If the wire is grounded, the gauge will read 0psi.
Hope this helps.
Lou
Hope this helps.
Lou
my gauges reads past 60 all the time whether the cars on or off
Engine: TPI
#1 A reading with the car off is completely irrelevant, the gauges are not controlled, they just "relax" and can show anything.
#2 As I said, locate the blue wire on the oil pressure sender and ground it on the block (or any good known ground). If the gauge reads zero (with the key ON, of course), your gauge is likely good.
Lou
Lou
ambainb
04-25-2016 09:21 PM
