Power Antenna
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Power Antenna
I pulled a power (retractable) antenna out of an 89 camaro and tested it out. The motor runs, but the antenna mast does not move and is stuck in the up position. I think the problem is that the mast is bent and the retracting cable or whatever pulls it down may be broken.
Is there a fix for this? Also, how can I get the mast out of the base?
Car: 87 GTA
Re: Power Antenna
Top Down Solutions has a kit for that. Common problem. I have a 89 GTA antenna just like that.
Car: 87 GTA
Re: Power Antenna
More than likely, the cable inside is broke. Apparently, I was mistaken about TDS...
But a search on TGO does wonders. Did you search?
https://www.thirdgen.org/forums/hist...ld-thread.html
1 Post
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Power Antenna
Thanks again
sailtexas186548
08-24-2015 10:11 PM
