MSD 6AL Wiring
MSD 6AL Wiring
hey guys i bought a msd 6al box, and i was wondering if instead of buying the harness(P/N8876), if anyone has just wired up their own. i dont see it being hard since all the plugs you need are all there, and its a good way to save 40 bucks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: MSD 6AL Wiring
You can do that if you want. The harness just makes it easier to bypass the box and run stock ignition again if something goes wrong.
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Re: MSD 6AL Wiring
If it doesn't work check the harness. I got 2 bad ones ended up hardwiring it. made 2 jumpers in case I need to bypass it. Dave
Re: MSD 6AL Wiring
I bought the harness, simplest MSD-6AL install I've ever done, and worked right off the bat.
tartagliaz28
08-15-2015 10:59 AM
