91 camaro, Autometer Speedo problems
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
So i got all of my gauges wired up ( pics later ) Autometer C2 all in dash. I calibrated my speedo all according to the instructions... right now i have and intermitant speedo and when it does work it goes to random speeds or it pegs... im thinking its a loose wire.. any other ideas??
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
Re: 91 camaro, Autometer Speedo problems
I would go back and check your ground for the VSS
I started this thread, let me know if you are having similar problems.
https://www.thirdgen.org/forums/elec...-problems.html
I am about to wire a switch in on the hot wire to the speedo and turn it on after the car has been started, inorder to keep it from hanging up all the time.
Car: 1991 Camaro RS
Engine: 357cid
i got it figured out... mine never hangs but my bootleg soldering came loose... re did it and no problems
92camaroJoe
08-13-2015 06:07 AM
beachrodder
08-07-2015 04:27 PM
