Brand New MSD Pro Billet distributor RUSTED!!!!!!!!!!!!!!!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
Has anyone had their MSD Pro Billet distributor rust yet??
HELP!!
HELP!!
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Brand New MSD Pro Billet distributor RUSTED!!!!!!!!!!!!!!!
where is it rusted?
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
MSD is junk... my distributor pinion which is locked to the shaft by a crappy threaded hex screw sheered loose while passing a greyhound bus approaching a bridge and oncoming traffic... while passing the bus, I lost power and my car died but still had enough momentum to pass the bus and swerve off the road... could of killed me and everyone on the bus I passed.
MSD and Mallory is the same thing pretty much.
Yeah, mine did that in there too. Just the rust, not the shearing. Ive had it for quite a long time and its never failed tho. I think there is an o-ring you can add if you screw it down instead of using the l-clamps
9192camaro
16
02-03-2019 12:21 AM
ambainb
04-25-2016 09:21 PM
396, billet, disitributor, distributor, distrubitor, gen, inside, msd, pro, products, rust, rusted, rusting, timing, wiring
