Engine bay wiring diagram?
Ok so as it says on my other thread that i just bought this camaro 91 that used to be a v6..but the previous owner did a swap..v8 carb
i opened the hood and there are bunch of wires tha are cut off..from the left side..the wires that are coming from the firewall.
so what id like to know is that those wirings..if there is a site or a diagram that would show me which color goes where...
Re: Engine bay wiring diagram?
Here are some diagrams for you to look over. They are the ECM plug diagrams for the 91 V6 engine. The printing is a bit small so download them to your PC and them blow them up to make them easier to read. You can use them to hunt down what each of the wires is for. You can also visit this post to see the drivers side firewall bulkhead wiring connections
https://www.thirdgen.org/forums/elec...body-92-z.html
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You mean a diagram for the instrument cluster? We have them all!
Go to our ATGO diagram page and scroll down maybe halfway, you'll find all the instrument cluster diagrams that you need. Including the connector pin out and wire function!
Hope this helps.
Lou
Hope this helps.
Lou
AkDrifted
08-17-2015 07:45 PM
