91 TA GTA beep sound problem
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Hi,
First there was few beep sound when I slide the key inside but now -i dont know what happened- the beep sound continues forever and on each beep my signals, parks and dashboard lights flashes scynchorizedly... Any guess? Help Please because under these circumstances I have to lossen up the accumulator's - pole and cut the hole car electric...
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Moderator/TGO Supporter
Car: 1997 Z28
Re: 91 TA GTA beep sound problem
i assume he is talking about unhooking the battery.
Engine: 502 Ram Jet
yes... you are right I am talking about disjointing the negetive battery cable...
Engine: 502 Ram Jet
Don't you have any idea???
Have you replaced any electrical parts recently? Bad brake, turn or light bulbs or switches etc.? Is your ignition switch in good shape? Does it do this when you insert the key? Do the interior and exterior lights come on and the warning buzzer sound when you depress the brake pedal?
Engine: 502 Ram Jet
Yes, it buzzes when I insert the key but the sound that I was talking is not that buzz sound. I just figured it out that there was sometihng wrong with my alarm system and when I remove the alarm the sound just went away... So the problem is solved. By the way In 91 (I dont know others have or have not) TAs have buttons on seats which are located at the door side. I believe that it's for pumping up the things which is for not drivening away from the seat in stong turns... I checked the pump under the seat and it is working so probably the problem is the electricity. I don't know the fuse for it. I don't know what is the cause of the problem? Can you help me? (especially with the fuses)
Thank you ...
Thank you ...
92camaroJoe
08-13-2015 06:07 AM
