92 camaro rs lost key resistor
Car: 92 camaro rs
Engine: 3.2
Transmission: stock auto
Axle/Gears: stock
hey guys, i have a 92 camaro rs that i just rebuilt for my daughter's 16 b-day. (she loves da muscle cars) it has run beautifully for about 6 months. Until yesterday when the little resistor fell or got knocked out of the key. The car has a 3.2 v-6 and all the threads i have seen referring to disabling the vats were for the bigger engines. Can I follow the same instructions? yellow wire from ignition switch connected to tan and white wire from gear selector?
any help would be appreciated as her b-day is today and i really wanted to be able to give her the keys and watch her drive off. thanks
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Re: 92 camaro rs lost key resistor
Car: 92 camaro rs
Engine: 3.2
Axle/Gears: stock
ok, i found a large diameter yellow wire but can't find the tan and white one. is it with the flat harness under the steering column? hhhhheeeeeelllllppppp!!!!!
