which high perf. ignition control module?
1 Post
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
decisions, decisions- accel, pertronix, or summit high perf control module:
http://store.summitracing.com/partde...044+4294840138
i heard somewhere that summit's ignition stuff is made by standard motor products. if thats true, forget summit. to be honest i'm leaning towards the accel unit. any suggestions?
P.S. i'm going to do everything else MSD- cap, rotor, coil, wires- i just dont like the MSD control module so much.
Re: which high perf. ignition control module?
None of the above, the so called performance ignition control models have a tendancy to go out rather quickly. Go with an AC-Delco
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I recently installed a new ignition module(GP Sorsen sp?) about 2mo ago and it went bad (and left me stranded) 2 days ago. Good thing I had my 20yr old AC Delco-GM module in the garage. Installed it and it fired right up....go OEM
Car: 77 Monte Carlo, 89 Firebird Formula
Engine: 355's
Transmission: TH350's
Axle/Gears: 10 bolt 8.5 3.73, 9 bolt 3.27
Went MSD and lasted a few years.. then burned up on the freeway.. then went to stock and didn't realize much difference in the car.. but threw in an accel.. all fullfilled their purpose
Ghettobird52
07-05-2024 11:18 PM
