Push button start
Old 04-27-2007 | 08:41 PM
houseparty4's Avatar
Car: Camaro z28
Engine: 350 TPI V8
Transmission: Automatic
Push button start
Ok guys well my car wont start... The ignition on/off isnt getting to the starter... My dads friend that was looking at the car said he could wire up a push button switch to start the car... I said hell yeah, but he couldnt do it today... So i want to try it myself... I have the wiring diagrams from the Haynes manual but i need help. Ok so i look under my column to see all the wires... Which wires do i tap into so i can start my car with a button ?
Also will a horn button work for the application ?
BTW its a 1985 Camaro Z28
Old 04-28-2007 | 01:31 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: Push button start
my 85 IROC is having the same problem. I think it is a fusible link down by the starter. I have a toggle switch wired up to mine, but i dont really like it and plan on correcting it when I drop in the new tranny (700R4).
oh, BTW...I wired it up directly to the starter with an inline fuse and a relay. I didnt realy mess with the wires under the column...seems to me that if your not getting getting power to the starter that it still wont get to the starter if you tap into some wires under the column with a switch or button...but I could be WAY off.
Old 04-28-2007 | 03:47 PM
Car: Camaro z28
Engine: 350 TPI V8
Ok well my dads friend hooked it up directly to the starter.. Works great
Old 04-28-2007 | 04:11 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
I wired mine up directly to the starter also. I put a momentary on/off push button in place of the cigarette lighter. Def. a plus
Old 04-28-2007 | 04:19 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
So ya'll wired it straight to the starter? I dont have an ignition in my colum nemore i took it out, cause i have remote start(viper alarm) but i am thinking of putting a push button start. by the way did u use a 10amp fue relay or lower?
Old 04-28-2007 | 04:20 PM
Car: 91 Camaro RS
Engine: Small Block
I didnt use a relay or fuse or anything. I've had mine in it for about 2 and a half years now and no problem yet. I used like 12 or 10 gauge wire though
Old 04-28-2007 | 04:23 PM
RocsRose86's Avatar
aight . thanks cause i have lost my remote like a dozen f'n times. and they r 100$ 4 each one so i need another way to start her up!cause where my ignition cylinder was is where my bass **** is now!
Old 04-28-2007 | 04:53 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
it you want to save the headack of running a wire to the starter all you have to do is drop the fuse box look for the heavy gauge purple wire and send 12V to it. this wire goes right to the starter. it bypass the nutrol safty and all that other ****
for more info IM me
Old 05-01-2007 | 12:34 AM
89_KITT's Avatar
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
hey guys i have a quick question. ive been having problems with my starter as well. it starts fine in mornings and stuff but then when i start it after it sits in the sun for about a few hours it wont start. so i was woundering if this was similar to you problems? and if its the vats. (btw the starter is a couple months old nib from auto store)my dad claims the vats is setting it off.i thought i might ack some opinions. and does anone have a diagram for a direct link to starter/toggle or push button? and could i run it threw the vats so it will only be enabled wit the key in the ignition?
Old 05-01-2007 | 01:38 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
i don't know if that is youre problem, i don't know a thing about the computers that were used in these cars but here is how i wired my push button start up:
2nd: to the Starter Button then out to the starter motor.
Hope it helps.
Old 05-03-2007 | 01:13 AM
89_KITT's Avatar
Engine: 2.8L V6
Axle/Gears: factory
thanks man i kinda understand it but i jus need a lil brush up on electrical so its all gray
Old 05-03-2007 | 01:30 AM
VenomX-87's Avatar
No probs, if ya need anything just P/M me and ill see if i can help.
Old 05-12-2007 | 11:26 AM
GTAfanatic's Avatar
if you want to run the switch from the fuse box just power one side of the crank fuse ffrom the back of the box, it should be a 3 amp purple fuse. this wire go right to the starter.
Old 03-25-2008 | 05:42 PM
jennifercarlson's Avatar
Car: 1991 Camaro RS
Engine: v6 LHO MPI
I am putting a push button start in my 1991 camaro rs I am just learning how to do this type of stuff so any input is good.......we didn't get the keys for the car when I bought it I got it at an auction so we bypassed vats but what all do I need to have a push button start I have read about different toggle switchs to one I don't want to use the keys to turn the ignition on so what do I need to do to make this work.
Orr89RocZ
04-25-2016 09:28 AM
The_Phoenix
02-04-2016 08:10 AM
smooth
08-18-2015 07:34 PM
86White_T/A305
08-17-2015 01:16 AM
Tony Ferrarri
08-11-2015 08:59 PM
