'87 5.0 FI WHERE IS THE FUEL PUMP RELAY?
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: '87 5.0 FI WHERE IS THE FUEL PUMP RELAY?
Fuel pump relay is on the driver's side firewall between the brake booster and the fender.Have you checked the fuel pump fuse.Check for loose connections also.
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
It is mounted to a bracket on the drivers side firewall. It is the one in the middle of the three on mine (however on some cars i have seen it to be all the way on the left of them). Check the fuse 20A fuse by the battery as well as the one in the fuse block. I remember fixing my fuel pump problem in my car. Dropped the tank for no reason. The problem was a cut wire under the dash.
