Wheres the speed sensor? - 91 Firebird
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Wheres the speed sensor? - 91 Firebird
If there was a problem with the VSS you'd have the Check Engine light on.
Car: 91 Bird
Engine: V6
Well the check eng light came on from time to time. Mostly over 3k rpm but I changed out that sensor today and everything is in perfect working order now. Infact the only problem I had was finding the sensor. I was looking in the front of the tranny bout ready to take out the solenoid for no good reason. I am without a doubt no mechanic but I get by. Thanks for the help.
Actually since I changed it, when I start it it revs pretty high by itself.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
