turn signal problems
Car: 86 Iroc Z/89 Firebird Formula
Engine: 355/305tpi
I got an 86 roc with a turn signal problem , I was getting no signals at all but had flashers.So I replaced the flasher now i have pass signals but no driv signals.Found the drivers front turn signal bulb on bumper wasnt working so i replaced the bulb still nothing.If i turn all lights on it works but as soon as you turn signal switch on it does not flash . Is it the socket the switch or the cam.any help is appriciated guys!!
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: turn signal problems
I would definately check the turn signal switch itself. I had the same problem and now it works fine. You have to take the column apart, but you'll get good at it.
Fronzizzle
03-18-2019 08:29 PM
