Where's the flip up headlight relay?
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I am having a hard time tracing the green and gray wires from the flip up motor to its relay... Does anyone know exactly where it is? A pic or a part # would really help!!! Thanks!
1 Post
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
What he said, but its about 3.5" square and a half inch thick. Not a little one inch cube like normal relays.
Car: 89 FORMULA 350
Engine: 5.7 L98
Thanks guys, i found it! But Is the module the big black box unit"with the two plugs in it" that probablly needs to be replaced? I pulled one of the plug adapters out with the 2 green and 2 gray wires and nothing looks out of the ordinary...
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Check the voltage to the relay module. Seems to be a coomon issue, could be a broken wire somewhere.
You can find all the diugrams you need in the 3rd-gen wiring diagrams section on ATGO.
Hope this helps.
Lou
Hope this helps.
Lou
Car: 1987 firebird
Engine: 2.8L v6
Transmission: auto
It sounds like you and i have a similar problem. I checked the voltage on mine and found a connector that was bad and had to jerry-rig a connector. The connector was about 2.5-3 feet down the wire from the headlamp assembly. You have to take the whole assembly aprt to get to it, but i hear that is the most common part that goes bad on them. You might want to give it a look.
Hope this helped
Hope this helped
Car: 89 FORMULA 350
Engine: 5.7 L98
Well, I ordered the new relay module from TDS and everything works as good as new! For now... Thanks for the help guys
