Problem with calibrating LM-1
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I got out my WBO2 meter for the first time. When I went thru the calibrate procedure described in the quick start guide, the meter got stuck on making one calibration pass after another. This meter went about 45 minutes like this. I finally gave up, and turned it off.
It never got to the "Calibration needed".
What is wrong?
What is wrong?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I would pull the battery from the LM1, reinstall and then attach it to an O2 sensor in free air (not mounted in the exhaust). That should reset everyting.
