how many wires ground to starter?
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
86 camaro. came with lg4. been having problems lately with guages and im thinking ground. then i remembered i have alot of wires grounding to a small starter stud. anyone know what wires should be grounding to the starter or have any pics?
im thinking i have one too many wires grounding.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally Posted by Lo-tec
No wires ground to the starter.....those are all hot wires.
im amused
the small single wire on the small stud all by itself is the solenoid wire from the ignition switch
all the rest of them bolt to the large stud along with the positive battery cable
and thats it, nothing to do with guages
if youre having a dash problem then i would remove the instrument cluster and clean and check all the contacts where the cluster plugs into the harness back there
some of the pins could be loose or bent,
this is a pretty common problem especially on the s-10 trucks and such, seen it happen a million times
but first make sure you have no wire touching grounding out melting on your exhaust anywhere, this is common to happen to, and when the temp wire or another wire get stuck to the exhaust then it can cause some funny things to happen
good luck
good luck
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally Posted by Fast68
im amused
good luck
good luck
Car: 1990 firebird
Engine: 3.1 v6
no ground stud there buddy. Only terminals on the starter are the S,B and M. S is the neutral safety/starter enable relay/whatever control side of the circuit. B is battery positive and M is for Motor power only
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
check the ground under the dash, its the #1 cause of most problems..
do check the wires and fusible links at the starter. one of the wires powers your interior and may have something to do with your problem.
red wire i think.
good luck!
red wire i think.
good luck!
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
