Starter hook up question
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
So I have an 89 camaro, originally had a 305 TBI and I have now swapped to a modified l98 setup. I wired up the starter and I was wondering which wires go to the LARGE post and which ones go to the SMALL post. I think there is a red wire, a purple wire, a black wire and maybe another black wire, I think. Any suggestions would be helpful....
here's my problem, The battery holds a charge while I'm not driving it. But I can;t drive it very far without the voltage meter dropping and the car stalling no mater what speed. Resuting in a dead battery. Alternator is new. Could something be off in the starter wiring?
1 Post
Car: 1989 Camaro RS
is the field wire the one I bolt on to the back of the alternator? Or is it the wires on top with the connector attached to them?? Should I trace these back to see were they go or what?
92camaroJoe
08-13-2015 06:07 AM
