Will Alternator Cause Miss or Stutter? Rough Idle?
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I pretty sure my alternator is not charging my battery. It was working before my engine swap but with the new engine and cranking it so much, I think I fryed it. Too much charging with the charger and the bolt on the back is close to the valve cover(tall, not stock short ones).
Will a screwed up alt. cause a tach to jump unnecessarily? Would it cause the engine to bog or idle roughly? The car wants to stall sometimes, is it because the is not enough voltage to keep it going?? The gauge reads around 8-9 volts.
Thoughts?
Thoughts?
eightsixseven
08-14-2015 03:09 PM
