4th Gen EMERENCY Wiring Problem............
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Well i picked up a 2000 Camaro Dash today. I started with the splicing of the wires and got the Headlights, Dimmer, and Fog light wired.. I am needing helping if anyone knows what these wires are im describing down below.
I believe these are for my rear defrost and power trunk, can anyone chime in and tell me if im right or wrong?
Wiring is:
1)Black, Blue, Purple, Pink, Grey
2)Black, Orange, Grey, Black/White
![](https://img162.imageshack.us/img162/1948/p10103715pm.jpg)
I'm also not sure what this connector is? its around the power trunk/rear defrost.
![](https://img162.imageshack.us/img162/5639/p10103726zk.jpg)
Ok these 4 connectors are all in the same picture.
#1 connector is circled in red, it came out of the back of the old heater, i know this is prolly where i hook up the HVAC but everywhere i look its more like 6 wires instead of 4?
#2 connector is circled in light blue, and just comes out from the firewall, any idea what these are for?
#3 connector is circled in yellow and also comes from the firewall and would like to know what its for.
#4 connector is circled in white, and comes from underneath the shifter and i have no idea where it goes, any ideas? my reverse lights dont work if that helps.
1) Brown, Orange, Yellow, Blue
2) Blue, Light Blue
3)Yellow, Brown
4) Orange, Brown
![](https://img155.imageshack.us/img155/5218/p10103739dl.jpg)
This connector has a brown and white wires, and comes from the main harness. Anyone know what these are?
![](https://img162.imageshack.us/img162/2540/p10103756ev.jpg)
This is the cluster connector from the 2000 Camaro, supposedly from an LS1, does ANYONE have the info for these wires/pinouts? please
![](https://img155.imageshack.us/img155/8269/p10103709jc.jpg)
Last one, this heating stuff, do i need to take this out to get the camaro dash to fit, seems like something is stopping the dash to go further back?
Wiring is:
2) Blue, Light Blue
3)Yellow, Brown
4) Orange, Brown
![](https://img155.imageshack.us/img155/314/p10103745mi.jpg)
on the trunk connector, you're only going to use 2 wires: orange and black/white. The other two wires are for illumination of the trunk switch and you wont need those
On the defrost switch, you won't need the gray illumination wire, thats all I know at this point.
I think the PIC #2 is something for the dimmer. Find your old dash and remove that part of the old dash and plug that part back in.
The connector is pic #3 should plug directly in to the heater controls, no need to splice anything on that connector.
The LS1 gauge cluster will not work unless you have a LS1 or dakota digiatal $80 or so converter. However, the wiring should be about the same as the LT1 cluster pinout except for 2 trouble lights, i beleive.
the heater stuff, I think leave what you have left of the thirdgen vent system in(that i see in the pic)
and cut the 4th gen ductwork and try to match up the 4th gen ductwork as good as you can by cutting it.
Then use some foam, kind of what like is under the bottom hush panels to fill in the gaps.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so the rear defrost, and the power trunk is in the first picture with the 2 connectors right?
so on the first connector i will be using black, blue, purple, and pink, and just not using the grey.
and on the 2nd connector i will be using the orange and black/white, where is the power trunk on the 4th gen dash anyway? i couldnt find it.
rear defrost and power trunk are in the first pic
sorry, i meant defrost switch connector, but yes, don't use gray wire
Power trunk should be on the panel that is below the steering wheel for 4th gen camaro years 97-02 and firebird years 93-02.
The connector with the brown and white(or gray) wires is for your top dash speaker.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thanks man your helping alot. do all camaro/firebirds have power trunks incase i cant find it?
does anyone have the pinout for the 2000 camaro cluster what each wire is for?
use this one, should be the same for all but 2 wires. http://shbox.com/1/95_ta_cluster_pinout.jpg
I'll warn you, your tach will be off, the LS1 pcm sends out a 4 cylinder tach signal and the LS1 tach is looking for a 4 cylinder tach signal.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
only because of the cluster right, changing to an lt1 cluster should work fine, im not worried about that for right now.
here is my connector, not sure which is #1 or if the connector is upside down but here is what i have.
A1 Not used
A2 Not used
A3 Pink
A4 Not used
A5 Tan?/White Line
A6 Not used
A7 Not used
A8 Brown/White Line
A9 Not used
A10 Orange
A11 Not Used
A12 Light Blue/White Line
A13 Purple/White Line
A14 Not used
A15 Not used
A16 Not used
A17 Light Green
B1 Brown
B2 Not used
B3 Grey
B4 Not used
B5 Purple/White Line
B6 Grey
B7 Orange/Black Line
B8 Dark Green/White Line
B9 Grey
B10 Dark Blue/White Line
B11 Black
B12 Not used
B13 Not used
B14 Tan
B15 Black
B16 Not used
B17 Not used
A1 Not used
A2 Not used
A3 Pink
A4 Not used
A5 Tan?/White Line
A6 Not used
A7 Not used
A8 Brown/White Line
A9 Not used
A10 Orange
A11 Not Used
A14 Not used
A15 Not used
A16 Not used
A17 Light Green
B1 Brown
B2 Not used
B3 Grey
B4 Not used
B6 Grey
B9 Grey
B11 Black
B12 Not used
B13 Not used
B14 Tan
B15 Black
B16 Not used
B17 Not used
I had problems with the LT1 tach working directly off of the coil anyway. So, might as well get that dakota digital thing to filter the tach, and change the signal, and then your LS1 tach might work
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok but the site you gave me was for 95z/95bird cluster, they dont look the same as mine.
do you or anyone know where there is wiring for 98-02? or preferably 2000 camaro
The wire colors might be different but the functions should be the same. Give thirdgen.org member knyghtmare a PM. I think i spelled the name right. Knyghtmare has a 98-02 camaro dash installed.
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
tried to look cant find nothing, i read MANY MANY posts on here with people using LS1 dashes, but nowhere are the wiring schematics
could someone please chime in with a 98-02 camaro cluster gauge wiring
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i got all the wiring for my 00 gauges, these are identical to my connector. i just want to know where is the temperature gauge? the battery gauge, and coolant low gauge? what about my fuel gauge?
also what says fused ignition feed, or fused battery feed, what do i hook those up to? i dont see any connectors on my 3rd gen for that? please help
Pin color use
A1-2-not used
A3---pink------fused ignition feed
A4---not used
A5---tan/wht--brake warning indicator lamp input
A6-7-not used
A8---brwn/wht-SES light
A9---not used
A10--orn-------fused battery feed
A11--not used
A12--lt blu------left turn input
A13--ppl/wht---seat belt indicator
A14-16-not used
A17--lt grn------high beam indicator
B1---brn--------park lamp feed
B2---not used
B3---gry--------security indicator input
B4---not used
B5---ppl/wht----fused ignition feed
B6---gry--------Class 2 Serial Data ***********
B7---orn/blk-----rear compartment lid ajar indicator
B8---dk grn/wht--vehicle speed signal
B9---gry---------instrument cluster lamp feed
B10--dk blu------right turn indicator input
B11--blk----ground
B12-13--not used
B14--tan---------oil pressure gauge input
B15--blk wht------ground
B16-17- not used
Pin color use
A1-2-not used
A4---not used
A6-7-not used
A9---not used
A11--not used
A14-16-not used
B2---not used
B4---not used
B11--blk----ground
B12-13--not used
B16-17- not used
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ive been reading and it seems that the tach, fuel, coolant temp info is all read from B6 - Grey - Class 2 Serial Data. They are all read through the computer i guess, but since i KNOW some people here use the ls1 wiring/gauges, someone must be able to help me??
