Temp & Gas Gauge Jumping
Location: South Bend Indiana iphone CALL OR TXT 574-607-2389
1 Post
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
I changed my plugs today, so needless to say I was laying all over the engine and now my temp and gas guage needles seem to jump all around when the car is running and worse when I accelerate. The temp guage eventually shows that its over heated anf buries the needle. I didn't think it even worked before. The car does not appear to be overheated though the guage reads it. Help! What have I done? LOL ! 86 Z28 305 Carbed 5 speed.
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
Sounds to me like on the tempature sending unit you knocked the wires around and its getting a bad connection somewhere. How bad does the gas gauge jump around? I know mine jumps around a bit, but thats from the gas sloshing around.
1 Post
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
all three of the Camaros i owned have the gas guage move around when I rev my engine, just took that as normal
Car: 92 Rs
Engine: lo3
my gas gauge buries the needle when you fill it up. like it goes way past the F. but its seems to some what work . when you fill it more than 3/4 of a tank thats when it drops. does yours do that
1 Post
Engine: 6.0 Vortech
Transmission: 4x4
The gas gauge may be normal jumping, I just got the car and only put gas in it once but it looks like the less gas in the tank. the more jumping. The temp thing is all messed up stuck all the way to the right at the moment until the car cools down. Where is the thing I need to fix?
Not good pics but is this the temp sending unit? How do I fix it?
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Car: 1987 Z-28
Engine: 355
I believe the temp. sending unit is in the drivers side head, right up near the front. Someone correct me if I'm wrong.
on my old car i crazy glued needles (actual needles) at the ends of the red and 0 on the oil and temp gauges. And my gas works fine normal full and empty but it does fluctuate when you stomp on the gas or brake. I blame that one on no baffles in the tank.
Ghettobird52
07-05-2024 11:18 PM
TA8487
Interior Parts Wanted
08-23-2015 01:34 PM
