how to remove the plastic to get to my hi low beam switch??
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
hello could someone please tell me how i get to my headlight turnsingnal switch.,.,on my 91 rs camaro i dont see no screws and ,.,.i realy need to get my high beems to work.,.,.,.,.,.,please help just to clerify im talkin bout how do i remove the plastic around the streerin wheel,. to gain access to the hi low beam switch also is the turn signal
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To clarify matters for you, you don't remove it since the hi-beam switch is not mounted in the steering column. it is mounted on the steering column above the ignition switch (not the lock cylinder for the key) under the dash. If you will do a of the board, particularly this forum, you will find several posts regarding this switch and its location. Also how to remove and adjust it as well.
no bro your reading me all wrong
im talkin bout the toggle you know how ya turn the signals on and off,.also how ya switch from hi beam to low beam.,.,.,now with that in mind how do i remove the hosing to get to it???????
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Then you need to clarify that and say that you want to remove the turn signal switch which is inside the steering column. To replace that you must first remove the airbag from the steering wheel without injuring yourself and then remove the steering wheel and the lock retainer.
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
Gotfuel,
You do know there is a metal bar behind that lever that runs to a switch under the dash that is mounted to the top right hand side of the column right?
If so and you've checked that switch out by manually actuating it then there may be something wrong in the column behind the steering wheel like trickster said. I recently had my column apart and the only thing back there for the high beams is the metal rod, A plastic piece that actuates the rod and the lever itself. unless that plastic piece is broke or has fallen out of place somehow i would look at the switch under the dash on top of the column.
Easy way to figure it out is if the lever clicks and sprigs back to the forward position when you try to turn on the high beams, the column and lever are good and the switch itself needs to be checked out/replaced.
J.P.
J.P.
How ion the world did that break? Did he hit it with a knee or something getting in/ou tof the car? That is the first time i have heard of that one.
Thanks Trickster,
J.P.
Thanks Trickster,
J.P.
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
mine is broke like that also, has been for 7 years now. if you push the turn signal away from you(activating the hi-beams) it just flops around and doesnt go very far back and never clicks
NBrehm
08-25-2015 11:49 PM
