Electric fan jury rigged
Car: 1988 Trans am
Engine: 305 TBI
I need to know if anybody can tell me whats up with this fan. The cooling fan has been jury rigged by a previous owner for some reason. The wire runs from it directly to the fuse panel and its stuck in an open slot. It constantly runs and I think its shorting the electrical system. Could this be because the cooling fan temp switch was bad. I dont know how to tell. Any help would be gladly appreciated.
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Okay it's jerry rigged, not jury rigged.
And the previous owner probably had cooling problems like the temp switch gone bad like you said or a hi tem thermo making car run hot in stop and go.
Do a search under cooling fans and you will find pages and pages of trial and error on the subject.
Welcome to thirdgen.org
TMZIrocZ350
10-07-2015 12:09 PM
