will early third gen window switches work with a later third gen?
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I have a 91 GTA with grey power window switches. I'd like to install black switches from an earlier thirdgen. Is this a direct swap?
If not, what needs to be modified? Different sized holes in the center console? Different wiring?
Thanks!
Bill
Thanks!
Bill
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
on camaros, the switch was identical every year except for the color of the trim and rocker... (and the printing on it)
on the birds, the wiring is identical, so its logical to assume that they didnt change the plugs, but even if they did, it could be made to work without much issue.
1 Post
Thanks guys!
I dont suppose anyone knows where I can find a comparison of all the different switches offered?
1992 Trans Am
05-10-2023 07:19 PM
The_Phoenix
02-04-2016 07:10 AM
