4 cyl. tach for a V8?
Car: 91 TPI Caprice
Transmission: TH700R4
hey folks, we are swapping a Camaro powertrain into a Mazda RX7, and i want to use the stock gauges of the RX7 - the problem: the Mazda had a 4 cyl engine - any ideas how i could connect the tachometer to the 8 cyl tach signal from the camaro?
i thought out there could be something like a "buffer" for this?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
An RX7 actually should have had a zero-cylinder engine.
I don't know if there's anything available on the market, but such a thing can be done fairly easily.
Car: 91 TPI Caprice
yes, i even had the idea to make my own circuit for that problem, i only thought there must be a ready-to-use solution on the market
Engine: 383 Carb
Transmission: 4L60
Considering how popular it is to swap an SBC into an RX7, there must be something. This probably isn't the place to look for it though.
