Fuel Level Gauge Wiring Yes Did A Search
Now my question is not how to wire my fuel level gauge, my question is this, i know there are 3 wires that come from the sending unit. But what do those 3 wires go to? One goes to ground (what color, guessing blk or brown) one goes to the ignition (guessing red or pink) one goes to the sender in teh fuel tank (no idea what color) so i need help with that. On the other note, after doing my own wiring job (swapped from FI to carb a long time ago and just got rid of taking all the wires that i no longer need out) so i cliped all those 3 wires and only have a little bit of them left still coming through behind the rear seats. So on the gauge i need to connect the ground one to the gauge, the sending one to the gauge, and connect the gauge to a 12 volt source? Do i have this all figured out right? But now my question is htis? How will my sender work if its no longer getting any power from teh ignition? Or do i have to re wire that wire to a 12 volt source as well and also tap my fuel level gauge onto a 12 volt source or does the tank not need a 12 volt source at all? Hope thats not too confusing, thx in advance fellas
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
This is from a '92 service manual but it may help.
The hot lead coming from the guages fuse is pink and black. The lead from the sender is a purple wire. The ground, as you guessed, is a black wire.
My Hayne's manual lists the hot lead as either pink/black or pink/white, the ground as black, and the sender lead as pink.
The sending unit does need a direct 12V source. It needs to have its own ground though.
Edit: I just realized that we are talking about a Camaro, not a 'Bird. Their guage clusters are different, so my answer may be off as far as wire colors are concerned.
How will my sender work if its no longer getting any power from the ignition?
Engine: 305TPI
Yes, the the "not" must have walked away while I was getting the morning coffee. I shouldn't post after 2AM and before 6AM, I always leave important bits out as I type. Sorry for the slip.
Car: 1987 Camaro RS
Transmission: 5-Speed
Hey let me know if you get your gauge working and how you wired it. I'm looking to do the same thing since my factory fuel guage doesn't work. Thanks
Car: 1989 Iroc-Z
Engine: 5.7L TPI
All you will need is the pink wire going from the fuel tank to the fuel gage and the black ground wire for it to work. The fuel sending unit works off OHM resistance and not a 12 volt power source. The 12 volt power source was for the fuel pump.
Ghettobird52
07-05-2024 11:18 PM
86IROC112
08-17-2015 02:00 PM
R3500
08-17-2015 12:16 PM
