Radio Settings Saver/battery ???
Car: 87 Iroc Z28
Engine: 355 TPI
Since I moved the battery to the rear of the car and installed a cut out switch, I have become extremily annoyed by having to reset the radio all the time when the switch gets turned off. So I had and Idea to add a battery to the 12 volt constant wire to the radio. I put a diode in so that the battery doesn't try to feed the entire cars electrical system. Will this work? Any suggestions ??
colton_carlson
03-08-2019 12:21 PM
