SLOOOWWW Electric Windows
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Ever since I disconnected the electric window motors for painting my window motors either go up and down really slowly and stop part ways (passenger side) or only goes down 1 inch and stalls (driver side).
I don't hear any grinding and the motor doesn't get louder or hum like it's being stalled. It just moves real slow and eventually stops before it goes all the way down or up.
Is it possibly the regulator? Or is it a bad motor? I checked the plug between the door and frame and it looks ok.
Anyone else have this problem???
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
u might wanna do a search, this topic is being covered now and alot in the past, good luck....
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Car: 92 Camaro
Car: '91 Firebird
Clean out the tracks and put some lithium grease it there.
Awhile back someone made super fast power windows by hooking a transformer up for more voltage... might be worth looking into also.
Car: 92 Camaro
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by mdricken
Wow I like that idea. Sounds like it would be a major project though since you have to go from DC-->AC-->DC again.
TMZIrocZ350
10-07-2015 12:09 PM
