What color is the EGR wire?
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
I have a connector at the back of the engine that looks like the right connector. The wire is green, is that correct? Thanks
If you are asking about the EGR vacuum solenoid valve connector, it should be a two-wire connector with a gray and a black wire in it. If you are asking about the EGR temperature diagnostic switch, it should be a single dark green wire. Yes, there is a connector for it near the distributor. Quite a nice tangle of wire back there, eh?
LT1Formula
08-20-2015 09:36 PM
mdtoren
08-16-2015 05:45 PM
