hotwiring radar detector
Car: 1990 firebird
Engine: 3.1 v6
so im picking up a radar detector tomorrow, i have been reading old threads but they are not very clear to me on how to hotwire the rd...is there a way that i can wire it to the map lights? , if anything i think i would pull one bulb out that way i wouldnt be driving around with a bulb on all the time ...of course id have to remember to hit the switch when the car is off...or if someone wants to explain how to hotwire it to the ignition system.... thanks
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Unless you want to mount it high for better performance and dont want to mess around with running wire up the a pillar...
edit: wait! I have it! Wire the radar detector to the dome light, and then just drive around with a door open!
Car: 1990 firebird
Engine: 3.1 v6
haha sounds good to me! , i was thinking the map lights because i believe the map lights have one wire that is always "hot" ...i want to mount it up high and i dont want to run it through the a-pillar, but hey whatever works
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by FirebirdNYC
so connect it to the ignition wire that runs into the fuse box...
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I took the dash top off and ran a couple wires down to the stereo to do mine. Basically I hooked the detector's power wire to the switched power wire on the radio and the ground to the ground wire. I routed the wires for the fuzz buster out of one of the defrost vents so you can't see the wire when it's not attached to the dectector. I set my radar detector low on the windshield in the center and it works like a charm.
eightsixseven
08-14-2015 03:09 PM
