90 Camaro Tachometer
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
Well, i posted this question on the body and interior board and not much came back! Maybe somebody will catch it here!
My 90 camaro's tach pegs when you turn the key on! but when you disconnect the battery the tach goes back to 0
-Could it be not grounded some where?
-How does the tach work?
-Could the eletronics in the coil be messed up? maybe a new coil would make the tack work?
thanks guys any help would be appericated!
Ivon
Ivon
ok fellas ! i am getting ready to buy a cluster from someone! any test i can run on the cluster to see if the tach works? Or even the connectors?
Any help would be greatly appericated!
thanks
ivon!
thanks
ivon!
Car: 1986 Iroc
Engine: crate zz4 350
HELP with Tach please
Ive had this problem before after getting my car jump started... i think it is becase there is a posative chargert somewhere in you car, everytime ive had this happen, jsut rev it up, and she kicks right back in..... but i just started having this problem today again, and it will go back to normal by giving it some gas, but it happens every time i start the car........... someone give us some suggestions PLEASE
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
