Is alternator worth fixing if 115 VAC fried it?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I pulled an idiot move recently and didn't disconnect my battery before I welded part of my SFCs in and fried my alternator. Is it fixable or am I better off just getting another one? I mean it's mechanically sound but if I can just replace something electrical inside it I will.
Thanks all.
Ed
Thanks all.
Ed
1 Post
Car: "02 z-28
Engine: LS-1
The regulator and diode package will run about $60-70 parts wise. You need to unsolder the stator from the diodes and open the unit assuming it's a CS 130. You can get a rebuild kit from www.alternatorparts.com Once you do one it's easy but depending on time and familiararity with soldering you may not want to do it.
Thanks guys. I've had good dealings with Alternator Parts before so I would use them again. I don't think I'd have a problem doing the work but for $139 the all new 140 AMP CS130 Iceberg alt is looking good. I'd just hate to throw away a good salvageable alternator if I didn't have to.
Ed
Ed
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Is alternator worth fixing if 115 VAC fried it?
Ed
Ed
Thanks for the input Don. But the only thing I've done to it recently was install the Alstons, and all of a sudden the alt craps out, so that led me to my decision. After doing the pull the cable while it's running trick, it told me the alt is dead. I'll be going thru the wiring soon though.
Ed
Ed
Hotrodboba400
12-10-2019 07:07 PM
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
