20 amp in line fuse
20 amp in line fuse
Ok folks, does anyone know what the plug attached to the 20 amp in-line fuse is? The 20 amp fuse that I'm talking about is attached to the side of the engine bay, right beside the battery.
The 20 amp fuse has an orange wire and a red wire. The red wire runs to this mysterious plug that I have no idea what it is.
I'm doing an engine swap and It seems that I'm missing a piece...... big suprise eh?
Hmmmmm ok so I'm probably going to have to buy another positive cable then...... Reason that I have this problem is that I removed the 2.8 in my 89 camaro and threw in a 5.7 out of 90. The positive cables must be different........... Crazy......
Thanks very much, off to GM!:hail:
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Re: 20 amp in line fuse
Second, when does the fuse blow? Right when you connect it? When you use the power locks? When you turn on the accessory position? Does the radio have to be on? Is it the factory radio? If not, what method was used to wire the new one in?
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
That fuse runs a lot of things. Anecdotally, a common cause of it blowing is the cigarette lighter socket shorted out by a coin or other metal foreign object.
Hotrodboba400
12-10-2019 07:07 PM
