fuel pump wiring for a 89 camaro
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
where did the fuel pump harness go through the body at on a 89 camaro, on my 84 trans am it goes out by the bumper but this camaro harness doesn't look like it does that.
anyone got a picture of where it passes through the body ?
thanks
thanks
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The connector is in the space between the rear seats just above the driveshaft hump. You may have to remove the trim and seats to pull the carpet far enough out of the way to access it.
thanks
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here you go! As you can see, it is in the center of the rear bulkhead and is held in place by two small rivits. The three wires run down the driver side under the carpet in a plastic runner.
Re: fuel pump wiring for a 89 camaro
Can someone specify what the three wire colors are to this connector and function. Making my own fuel pump harness. Thanks in advance.
Car: 87 Camaro Multi-port Fl
Engine: Ls 5.3
Transmission: 4L 60 E
beachrodder
08-25-2015 08:05 AM
