were can i find the fuel pump relay
Old 03-02-2004 | 02:13 PM
1987ws6tpi's Avatar
were can i find the fuel pump relay for a 1990 camaro 3.1? i looked on the fire wall and non of thoes are it i un pluged all of them and the fule pump still pumps
Old 03-02-2004 | 09:08 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
My manual shows it on the firewall with the fan relay and the compressor relay for the V6. And someone with a '91 recently had a bad fuel pump relay, and his was there. So one of those three should be it--I think the farthest one in.
Old 03-03-2004 | 08:38 AM
dmason's Avatar
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
I just rewired mine, I can shoot you a picture if you need it. Let me know. It is on the firewall, driver side. I can give you the wire colors if it helps. I know there is an orange and a tan. Tan is the one to power the pump if you bypass the relay.
Old 03-03-2004 | 01:20 PM
1987ws6tpi's Avatar
hay thanks man
that pic would be help full thanks again
Old 03-03-2004 | 01:23 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
yes, drivers side by the wheel well. there should be 3 black boxes. one of which is the relay you spoke of
Old 03-03-2004 | 01:31 PM
1987ws6tpi's Avatar
see the weard thing is that i unpluged all of them and the fuel pump still pumps. by my pass side head light there is a fuse that when i unplug it it shuts the fule pump off , the wires from that fuse are taped together with some other wires so i dont know if there is somthing missing. the color of the wieres that come out of the fuse are red and oreng.
RazorN8
01-07-2022 11:44 AM
89GTAOz
05-16-2020 09:31 AM
mustangman65_79
04-14-2017 05:37 PM
Kaweh
08-09-2015 02:54 PM
Quick Reply: were can i find the fuel pump relay
