Dismantling airbag in 1990 z28? HOW?
Car: 1985 Camaro
Engine: 350 ci 4 bolt main .30 over forged fed mogul pistons
I've found a donor car for my v8 swap. In taking parts off, I noticed the cool more modern looking steering wheel. The only problem is, I'm like 50% sure it's got an airbag in it. How can I go about a.) removing the wheel without the bag firing and b.) taking the bag totally out? Thanks in advance for all comments!!!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Disconnect the battery (if installed) and look behind the steering wheel. You will find four bolts, remove them and gently tilt the airbag back without removing it. Behind the airbag you will see a yellow wire with a harness connector, disconnect that and finish removing the airbag.
The Trickster!!!!!!!!!!!!!
