Rear Defogger Problems!
Car: 1992 RS
Engine: 3.1
I am having problems with my 1992 Camaro's rear defogger and brake light. I was wondering if anyone has a wiring diagram so i can try to fix it. If anyone else has had problems with this, can you tell me how you fixed it?
Car: 1984 z28
what type of problems are you having, the problem i was having is everytime i hit the brake the rear defog would come on, if this is the case, check the connections on the rear hatch shocks and see that they are tight.
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
Same with my defogger. It'll work in the top portiong then about half way down it won't work for maybe 4 inches and then works the rest of the way down
pain in the a$$
pain in the a$$
hectre13
12-11-2023 08:14 AM
