1984 Berlinetta Wipers
Car: 1984 Camaro Berlinetta
Engine: 383
I've got the digital camaro and my wipers don't work right. When I push the button to turn them on they short cycle back and forth in the parked position. When I got the car it didn't have a motor and I have deleted a lot of the wiring (pollution control and sesors etc.) so I might be missing something? Is there supposed to be a plug hooking to the three pronged control box connector on the washer pump? Mine doesn't have any.Chevy dealership wants $245.00 for a new Control Box , hate to throw expensive parts at it without knowing if that's the problem.Thanks.
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
245.00? that doesnt seem right..I would say to ask someone who knows what youll need, how to do it, and save some trouble first. Then try to find the parts you need at a local auto parts store. Good luck. Ive got a problem with my wipers too. However it should be fixed 2-morrow. A friend installed a heater core and knocked something loose.
Nate
Nate
my berlinetta did the same and the fuggers would also shut off at mid stroke ,I took the control pod out and cleaned the terminals with scotch brite and have been working ok ever since 20 years old lots of dust and flattened terminals
Engine: 383
Control Box
The box right above the motor for the wipers. It's model specific to Berlinettas 84-86 and expensive.
Car: 1985 Berlinetta
Engine: 305 4BBL
There is a Berlinetta expert on the board. Look for John in RI. He also has a website berlinetta.info . He can answer a lot of questions and he may have the part you need for sale. He has helped me quite a bit.
Linson
10-01-2015 09:50 PM
1984, 8486, berlinetta, buttons, camaro, chevy, heaterwiper, inop, motorwindshield, pod, problems, wiper, wipers, work, wpump
