Oil Pressure Sender
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Oil Pressure Sender
Hallo to everybody !!!
Iīve swapped my engine ( 1985 / 305 / TPI ) for a 350 ( donīt know the year, the casting-number is 10054727 ).
Cause my oil pressure reading is very inaccurate ( while idling next to the red mark, while cruising about 20 to 30 PSI ), I wanīt to install an new pressure sender. Now my question : At the moment I have the 1 wire bell shaped thing next to the distributor. Can I use the 3 wire combo sender/pressure switch and whatīs about the connectors ?
Thanks,
Uwe
Thanks,
Uwe
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
No, you can't use it. You need to get a 1-wire replacement. Those things go bad a lot. And they will ask you what your guage goes up to. Ours are 60.
Car: 1985 IROC-Z28
Engine: TPI 350
TTT
Only one opinion ??? - Perhaps I should mention that my new engine is newer than the old one. ( one piece rear main seal / center bolt valve covers )
Uwe
Uwe
Originally posted by Uwe 1985-IROC
TTT
Uwe
TTT
Uwe
Just get a new sender for what you have. I would reccomend getting an AC Delco sender. I've tried the aftermarket ones and none of them lasted more than a month, the Delco replacement is going on 10 years old now and works fine.
Car: 1985 IROC-Z28
Engine: TPI 350
Morley,
thank you for your response. Perhaps youīve a part-number for me, cause in Germany itīs hard to get the right parts.
Uwe
Uwe
Morley,
Uwe
Morley,
Uwe
10007393
14036243
Here is a little something I found on them:
GENERAL MOTORS 10007393
14036243
CHEVROLET..........................1990-1981
CHEV/GMC TURCKS & VANS..1990-1981
OLDSMOBILE.........................1989-1978
PONTIAC...............................1988-1980
0-3 PSI - 00-05 ohms
3-7 PSI - 13-26 ohms
45 PSI - 55-83 ohms
60 PSI - 70-105 ohms
So with a set up like a mityvac to apply pressure and an ohm meter you can check yours to see if it really is malfunctioning.
