Headlight Relay?
Car: 1991 camaro RS
Engine: 305 Carb
Headlight Relay?
Does anyone know where the relay is located for the headlights? I am having some serious wiring problems and i think it might be related to this. Oh, and its on a 91 rs camaro.
Thanks.
Thanks.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Stock, there are no headlight relays on the Camaros. There's the dash switch to turn them on, and the switch down on the column to toggle between high and low beam.
Pete
Pete
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Headlight Relay?
Thanks.
Thanks.
you shouldnt have a headlight relay...
but if you add one to these cars, the headlights get a good bit brighter.
Originally posted by noc_81
Well... on my '82 t/a, the relay is right beneath the front of the car. Try lying on your back and looking inside the nose, and you'll probally see them dangling near the headlight motors.
