Blinker Light Trouble HELP PLEASE
Recently one of my blinkers stopped working and just turned solid. So I went and replaced all the the bulbs in the entire car. And still only one blinker worked. Then a couple days later both blinkers stopped working. No solid lights nothing, not even anything in the dash. But when I turn on the headlights all of the lights turn on every single one. Also I went and replaced both flashers and the Turn signal fuse. Help what can I do, I heard it might be a ground somewhere but I don't know where to look.
HELP
Nick
HELP
Nick
there is a box behind your kick panel on the drivers side the 1 where the door chime in it and it also houses you blinker relay, replace your blinker relay hope tha fixes your problems bro
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
wow looks like i rubbed the bad blinker thing off on everyone else..sorry peeps!! lol....cant believe how many people are having blinker troubles
Car: '86 Transmaro
Yeah thanks a lot ^. For some odd reason my left blinker light in my car stays on constantly. I noticed that my front left blinker is out, so maybe that is just an indicator saying it's out.
Re: Blinker Light Trouble HELP PLEASE
recently found a bad ground inside light socket plug itself, front drivers side I forced it in really hard light started blinking hope this helps thinking of cutting out socket and replacing it
Car: 1984 Trans Am
Transmission: 5-speed
Yep I got the same issue here altho mine would work every once in a while, is there an actual replacement available for the socket without having to butcher the wiring harness?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Socket Situation
ClassicIndustries.com has sockets.
Depending on your skill, you will be able to solder the wires downstream and reinstall or replace the factory covering or loom, and it will look original.
Happy Racing!
Happy Racing!
“Just One Of Them Racin’ Deals”
