VSS Problems - Cruise Control
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I added a Rostra cruise control to my car. Only one problem, my 82 T/A did not have a VSS mounted behind the speedometer because it had no ECM from factory. AFAIK, the VSS is supposed to send out a pulse signal, 2000 pulses per mile for 82 VSS's I think.
Checked all electrical connections, custom switches, etc. All checks out fine. Only things I didn't check are tach signal, which should just be a cutout for overrevving I think.
Anyways, I added a VSS from another junked Firebird, I thought maybe this could be my problem. I hooked up a multimeter and went for a drive to see if I could tell if it was working. I THOUGHT it should go +12V...0V...+12V...0V, etc. Instead, I just got constant battery voltage. It didn't seem to vary. Is that correct? Could the pulses be so fast my multimeter can't keep up? (I tried to drive very slow). I'd really like to get this to work! Thanks!
Ghettobird52
Yesterday 11:18 PM
eightsixseven
08-14-2015 03:09 PM
Street Lethal
08-13-2015 08:28 PM
